should I downgrade?
should I downgrade?
I'm currently on 'Premier' (1Mb) and I'm wondering if I should downgrade to 'Plus'.
99% of my traffic is http with occasional P2P.
Is there anybody out there who has done this? Does the change of contention make any difference in practice?
Any thoughts most welcome.
1 REPLY
LiamM
should I downgrade?
For normal web browsing, email, http stuff etc... Broaband Plus is a superb package. For P2P it can be abysmal and normally is. Rarely does it go above 10k if that in P2P speeds.
It's up to you, if you only do about 1% P2P, then I'd say BB+ is fine.
