setting up
setting up
can you please tell me the following to install plus.net
1/connection type= ?
2/ ip assigned by isp- yes or no
3/vpi/vci= ?
4/ encapsulation= ?
5/mtu = ?
regards mike mcguire
setting up
Have you checked out this guide?
1/ Not too sure about this option on your router - what make/model are you using?
2/Either, may as well leave as Yes [or auto]
3/VPI=0 VCI=38
4/PPPoA
5/ I use 1458 without any problems, but people have varying opinions on the best to use.
Plusnet Staff
Plusnet Staff
Fixes: 159
setting up
Hopefully the settings here will help you set this up, I can see you have also had a reply with the settings and a link but here is the list direct from the help site
Username username@plusdsl.net
Password Your usual PlusNet password
Data Circuit Information
VPI = 0 (Virtual Path Identifier)
VCI = 38 (Virtual Channel Identifier)
Data Link Encapsulation PPPoA
PPP Properties VC Multiplexed
These can also be found at the following page
http://www.plus.net/support/broadband/help_and_setup/connections_settings.shtml
 Chris Parr
 Plusnet Staff
