setting up of modem
obitus
setting up of modem
erm i know its pretty simple Shockedops: but just to make sure ive installed the usb modem and when connecting all the wires etc i noticed the instruction booklet showed a different way than i had it set up. i have the adsl cable lead which came with the modem connected to the "line" and the other end into the spliter. i then have the telephone line into the other section of the spliter.
is this right as after a while online the quality seams to lower and i have this cream thing with "visionnet" on it which is just sitting there...lol :? is this right?
1 REPLY
setting up of modem
It sounds right. If you have the USB Modem Supplied by plusnet (Dynamode A360), then the only thing you gotta be sure of is that you dont plug the wire from the splitter into the phone socket on the modem. Slow speeds can be caused by a number of things. Look around this forum.
