server timed out
server timed out
i cannot send email out through ms outlook it hangs for a while then it says
sending reported error [0x8004210b] the operation timed out waiting for the response from the sending [smtp] server. if you continue to recieve this message
contact your service administrator or internet service provider the server responder [550] sender verify failed
sorry to keep posting messages but i need to sort it out thanks
server timed out
not having any problems here. It definatly sounds like a problem with your firewall or your antivirus.
Also make sure that in outlook you haven't Log on using SPA and also if you press more settings and then the outgoing tab make sure that "my server requires authentication" isn't ticked
server timed out
no everythings fine i aint even got my antivirus or firewall switched on
server timed out
are you connected to the internet via a plusnet connection? I just noticed that it mentions error 550 which means relaying denied, you usually see it when you done have authorisaton to connect to the smtp server, in terms onf plusnet it means that you are connecting to them via a non plusnet IP address
server timed out
i have turned the firewall antivirus off and now its working but i need help on something i set up a email adress on outlook via a mailbox ect its been set up for 2 days but i cant recieve email through outlook but im getting it in webmail i have just set up another account and that is working all correctly recieving emails via outlook ect what could the problem be
server timed out
Paul can I suggest you have a look at the help guides as these are pretty much fool proof.
Setting up outlook
Setting up Mailboxes
