running a mud (multi user dungeon on my machine)
PhillipH
heya
ok ive set up a mud on my computer (multi user dungeon) and i can connect to it myself of my own machine and everything is great.
however - nobody else can connect to it.
is this a dns problem? or dont plusnet allow such things?
if i need to reconfigure my router i need help with this.
thanks
PhillipH
RE: running a mud (multi user dungeon on my machine)
ok well it appears that it is indeed a adsl problem.
if i connect using my dial up - other ppl can connect to the mud happily.
so what is it i have to do wif my adsl for that to accept ppl connecting to my port 4000 ?
thanks
> thanks
I would check things like your firewall settings, we don't block inbound traffic.
Regards,
Mike
| Mike Grice....................Unmetered & ADSL solutions
| Technical Support.....................for Home & Business
| PlusNet Technologies Ltd.........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
shellsong
You say you're behind a router? And the MUD's running on port 4000?
How you do it depends on the router, but you need to configure your router so that all traffic to port 4000 is pointed to the IP of your computer (internal IP within your network).
