retrieving emails??
retrieving emails??
im having confusing email issues
i decided to try the beta email and i get email in there that outlook hasnt previously picked up?
like i used it yesterday for first time and i had emails iv been waiting for that outlook express had decided hadnt been sent
but as soon as i logge din they were there??
any ideaS?
i use 2 emails addresses but that shouldnt matter should it?
cheers
chris
retrieving emails??
Do they also exist in the existing portal webmail?
When using Beta webmail are you using the POP3 or IMAP service? If IMAP, do they appear when your select POP3. If so outlook should also see them.
Other than a possible corrupted header, I can't think of any reason why your email client should not see them.
retrieving emails??
im using pop
its that ill have emails from stakesbyarmsfc@stakesbyarmsfc.plus.com in the beta and secretary@stakesbyarmsfc.plus.com in outlook, the 2 dont appear in the one if that makes sense?
cant qite put my finger on it
chris
