refferal?
refferal?
lo, i referred a friend through Plusnets refferals thingy, they signed up and made sure plusnet knew i was reffering them, they are now connected to plusnet and they have recieved their upgrade to 2Mb, im pissed :x i have had no upgrade and no money taken off my bill :?: no point in referring then?
1 REPLY
LiamM
refferal?
Use this link and see if your referral is listed here. How long have they been with Plusnet? You will not receive a discount until their billing cycle is initiated.
If they're not listed there, then it's likely that your username wasn't given at the correct point when your referral signed up.
If this is the case, then you can change this, by getting your friend to raise a ticket with Plusnet and get your username added.
