recieved bt router 1800hg, not complete
Danglese
Hi, requested and was sent a BT wired router 1800hg. The security seal on the box was broken. Missing inside was 1 instillation disk. I simply dont know how to get it working without the disk. If there is a site that you know of where I can download the software, please link it otherwise send me the missing disk. Thanks, Danglese. ps also no instruction manual. Have now downloaded and installed the driver..
Aterlatus
This product is designed for BT Broadband and will not work with any other broadband service, including BT Yahoo! Broadband.
That concerns me slightly...
@danglese
See here for a setup guide for your router.
@stesherlock
This is not an issue for the batch that PlusNet have purchased.
Aterlatus
Ahhh, didn't realise it came straight from plus. Ignore my previous post, info just came from a quick browse while I was trying to be helpful ;p
Always good to know someone more knowledgeable than me is just around the corner. /grin
Danglese
I seem to have sorted it out, it didnt help that I had turned off LAN in bios about 2 years ago and forgot about it..anyway, thanks for the help, Danglese
