"fair usage"
"fair usage"
OK can some one explain to me in lame terms how this would effect me as a user
I have a 512k connection .....
how will other connections suffer from this "fair usage polocy"
"fair usage"
How much data do you download each month?
"fair usage"
varies.....
abotu 100gb a month Shockedops:
but my pc is on all the time,
i use it as a webserver as well as a facility to back up remmotly from my other PC at work
"fair usage"
Then the chances are you will be affected, but it depends on how much of that 100GB is upload, which is not counted in the fair usage system.
I suggest you read http://www.plus.net/support/faq/broadband_fair_usage_faq.shtml and http://www.plus.net/features/usage_guide.shtml
