"Telehouse East, Redback 2"
You are currently connected to the "Telehouse East, Redback 2" gateway.
I thought these had been replacedHuh
There is still 1 redback in use though, so maybe you got provisioned on it. It;s an overflow for one of the Junipers if the max connections exceed 32,000 I think.
Ah, OK.
I thought they had all been removed.
I don't know if it is chance but I was seeing poor speeds for the past hour and that is why I checked. I have reconnected onto Juniper 2 and things are OK again.
Regards
