"Path Mode - Interleaved" on D-Link G604T
Browsing affects are unknown. I have interleaving on my line and have not noticed any difference in speed. Ping times are less critical for browsing as it downloads data in bulk, with games, they require a quick send/reply sequence so ping times increasing can impact the game response times.
Hi, On the DSL Status page of my d-link it says..
This mean i have interleaving on?
Also says DS Margin 5 (SNR?) this any good?
And i know my attentuation is crap..
DS Line Attenuation 57
Yes, your connection is using interleaving which means you ping times may be slower (i.e. higher) by a factor of 2 or 3.
The 5dB SNR is normal for a Max enabled line as the exchange tries to achieve the best sync speed while keeping the SNR at or above 6dB - as sync speed increases, SNR decreases.
Tits, Thought id been connecting too often.
I dont game, will this effect normal web browsing 'response' times or downloading?
Still not had my BRA increased in size anyway so still downloading at 1mb! Sync'd at 2600ish
Ok thanks, may ask for it to be turned off anyway. More bothered about getting my speed up to what it should be.
Early june im told :roll: So much for 10days, more like a month+
Turning off interleaving is likely to reduce your sync speed and thus your data rate.
The reason interleaving is turned on is to allow a higher stable sync rate.
If you don't do gaming I suggest you leave it as is and monitor things.
Just so you know Cheesy
Ok, I guess.
