"I feel the need for speed"
I requested an upgrade to 2meg from +net and the advised me that bt need to upgrade the line. I checked the time frame this would be done by bt, and they said it woukd be July. Guess what? still waiting. Can sombody let me have the web address that i can see what progress they are making.
Is this a paid upgrade you are referring to or part of the free process?
Its the free upgrade. Just trying to find out when BT will be doing some work.
I presume from your username you are not familiar with bt?
Unfortunately that information does not exist. BT are running quite a bit behind with this upgrade schedule. the only information to go on at the minute was the "rough guide" as published by BT.
