"Connection reset by remote host" - ftp problem
I'm having lots of problems with ftp access to my plusnet webspace. Whenever I try to upload a reasonably-sized file (over 500Kb) I eventually get a "connection reset" error. This happens with windows ftp, bulletproof ftp...I don't _think_ its a software problem on my machines....
Any ideas? Do I need to raise a ticket on this d'you think?
Cheers
K
This seems to be a problem that isn't a priority with PlusNet at the moment.
See this thread.
Maybe one day it will be fixed but it is a pain trying to upload large files.
Does it make a difference using passive or active FTP or does it happen with both?
Cheers
Zen
Zenkai - couldn't tell you - as far as I can tell, all of my connections happen in passive mode...
