quite a strange thing going on....
Hello there,
My Internet gateway is an OpenBSD box with a Thomson USB ADSL modem.
User space ppp is providing the Internet but occassionally the modem, whilst syncing, manages to get a different IP address and gateway IP.
Below is a section of /var/log/ppp.log when this occurs:
Mar 7 07:02:45 beckett ppp[28910]: tun0: Command: default: set ifaddr 10.0.0.1/0 10.0.0.2/0
Mar 7 07:02:45 beckett ppp[28910]: tun0: Command: adsl: set authname poncenby {at} plusdsl.net
Mar 7 07:02:46 beckett ppp[28910]: tun0: Command: adsl: set authkey ********
Mar 7 07:02:46 beckett ppp[28910]: tun0: Command: adsl: set device !/home/luser/ppp/pppoa2 -vpi 0 -vci 38 -v 1
Mar 7 07:02:46 beckett ppp[28910]: tun0: Command: adsl: accept chap
Mar 7 07:02:46 beckett ppp[28910]: tun0: Command: adsl: set speed sync
Mar 7 07:02:46 beckett ppp[28910]: tun0: Command: adsl: set timeout 0
Mar 7 07:02:46 beckett ppp[28910]: tun0: Command: adsl: enable lqr
Mar 7 07:02:46 beckett ppp[28910]: tun0: Command: adsl: set lqrperiod 5
Mar 7 07:02:46 beckett ppp[28910]: tun0: Command: adsl: set redial 15 10000
Mar 7 07:02:46 beckett ppp[28910]: tun0: Command: adsl: set dial
Mar 7 07:02:46 beckett ppp[28910]: tun0: Command: adsl: add default HISADDR
Mar 7 07:02:46 beckett ppp[28910]: tun0: Command: adsl: enable dns
Mar 7 07:02:46 beckett ppp[28910]: tun0: Phase: PPP Started (foreground mode).
Mar 7 07:02:46 beckett ppp[28910]: tun0: Phase: bundle: Establish
Mar 7 07:02:46 beckett ppp[28910]: tun0: Phase: deflink: closed -> opening
Mar 7 07:02:46 beckett ppp[28910]: tun0: Phase: deflink: Connected!
Mar 7 07:02:46 beckett ppp[28910]: tun0: Phase: deflink: opening -> dial
Mar 7 07:02:46 beckett ppp[28910]: tun0: Chat: deflink: Dial attempt 1 of 10000
Mar 7 07:02:46 beckett ppp[28910]: tun0: Phase: deflink: dial -> carrier
Mar 7 07:02:46 beckett ppp[28910]: tun0: Phase: deflink: carrier -> login
Mar 7 07:02:46 beckett ppp[28910]: tun0: Phase: deflink: login -> lcp
Mar 7 07:02:46 beckett ppp[28910]: tun0: Phase: Unknown protocol 0x0077 (unrecognised protocol)
Mar 7 07:02:46 beckett ppp[28910]: tun0: Phase: bundle: Authenticate
Mar 7 07:02:46 beckett ppp[28910]: tun0: Phase: deflink: his = CHAP 0x05, mine = none
Mar 7 07:02:46 beckett ppp[28910]: tun0: Phase: Chap Input: CHALLENGE (16 bytes from ESR3.Ilford5)
Mar 7 07:02:46 beckett ppp[28910]: tun0: Phase: Chap Output: RESPONSE (poncenby@plusdsl.net)
Mar 7 07:03:30 beckett ppp[28910]: tun0: Phase: Chap Input: SUCCESS
Mar 7 07:03:30 beckett ppp[28910]: tun0: CCP: FSM: Using "deflink" as a transport
Mar 7 07:03:30 beckett ppp[28910]: tun0: CCP: deflink: State change Initial --> Closed
Mar 7 07:03:30 beckett ppp[28910]: tun0: CCP: deflink: LayerStart.
Mar 7 07:03:30 beckett ppp[28910]: tun0: CCP: MPPE: Not usable without CHAP81
Mar 7 07:03:30 beckett ppp[28910]: tun0: CCP: deflink: SendConfigReq(1) state = Closed
Mar 7 07:03:30 beckett ppp[28910]: tun0: CCP: DEFLATE[4] win 15
Mar 7 07:03:30 beckett ppp[28910]: tun0: CCP: PRED1[2]
Mar 7 07:03:30 beckett ppp[28910]: tun0: CCP: deflink: State change Closed --> Req-Sent
Mar 7 07:03:30 beckett ppp[28910]: tun0: Phase: deflink: lcp -> open
Mar 7 07:03:30 beckett ppp[28910]: tun0: Phase: bundle: Network
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: FSM: Using "deflink" as a transport
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: deflink: State change Initial --> Closed
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: deflink: LayerStart.
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: deflink: SendConfigReq(1) state = Closed
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: IPADDR[6] 10.0.0.1
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: COMPPROTO[6] 16 VJ slots with slot compression
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: PRIDNS[6] 212.159.6.10
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: SECDNS[6] 255.255.255.255
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: deflink: State change Closed --> Req-Sent
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: deflink: RecvConfigReq(1) state = Req-Sent
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: IPADDR[6] 217.47.22.134
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: deflink: SendConfigAck(1) state = Req-Sent
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: deflink: State change Req-Sent --> Ack-Sent
Mar 7 07:03:30 beckett ppp[28910]: tun0: CCP: deflink: State change Req-Sent --> Stopped
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: deflink: RecvConfigRej(1) state = Ack-Sent
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: deflink: SendConfigReq(2) state = Ack-Sent
Mar 7 07:03:30 beckett ppp[28910]: tun0: Phase: deflink: IPV6CP protocol reject closes IPV6CP !
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: deflink: RecvConfigNak(2) state = Ack-Sent
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: IPADDR[6] 81.152.93.15
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: IPADDR[6] changing address: 10.0.0.1 --> 81.152.93.15
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: PRIDNS[6] 194.74.65.98
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: SECDNS[6] 193.113.211.125
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: Primary nameserver set to 194.74.65.98
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: Secondary nameserver set to 193.113.211.125
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: deflink: SendConfigReq(3) state = Ack-Sent
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: deflink: RecvConfigAck(3) state = Ack-Sent
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: deflink: State change Ack-Sent --> Opened
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: deflink: LayerUp.
Mar 7 07:03:30 beckett ppp[28910]: tun0: IPCP: myaddr 81.152.93.15 hisaddr = 217.47.22.134
Mar 7 07:03:30 beckett ppp[28910]: tun0: Command: adsl: ! sh -c /sbin/ifconfig pflog0 up
Mar 7 07:03:31 beckett ppp[28910]: tun0: Command: adsl: ! sh -c /sbin/pfctl -f /etc/pf.conf -e
Mar 7 07:03:32 beckett ppp[28910]: tun0: Warning: 0.0.0.0/0: Change route failed: errno: No such process
Mar 7 07:03:32 beckett ppp[28910]: tun0: Warning: ff02:7::/32: Change route failed: errno: Network is unreachable
Mar 7 07:03:49 beckett ppp[28910]: tun0: Phase: deflink: HDLC errors -> FCS: 0, ADDR: 0, COMD: 0, PROTO: 1
Mar 7 07:04:54 beckett ppp[28910]: tun0: Phase: Signal 15, terminate.
Mar 7 07:04:54 beckett ppp[28910]: tun0: IPCP: deflink: LayerDown: 81.152.93.15
Mar 7 07:04:54 beckett ppp[28910]: tun0: IPCP: deflink: SendTerminateReq(4) state = Opened
Mar 7 07:04:54 beckett ppp[28910]: tun0: IPCP: deflink: State change Opened --> Closing
Mar 7 07:04:54 beckett ppp[28910]: tun0: IPCP: deflink: RecvTerminateAck(4) state = Closing
Mar 7 07:04:54 beckett ppp[28910]: tun0: IPCP: deflink: LayerFinish.
Mar 7 07:04:54 beckett ppp[28910]: tun0: IPCP: Connect time: 84 secs: 0 octets in, 0 octets out
All the above basically means I am given this IP address 81.152.93.15 and this default gateway IP address 217.47.22.134.
My static PlusNet IP address is 80.229.252.104.
Any idea why I am being given a different IP and gateway?
Thanks in advance
poncenby
1 REPLY
I see your log is from the 7th - I had a similar problem here - http://portal.plus.net/central/forums/viewtopic.php?t=39811
Some people might notice this at the moment, as due to the issues with our radius server people are occasionally being assigned a different IP address to the one on their account. This will be resolved once the underlaying connection issue is fixed.
