python-forum.org
megadyptes
python-forum.org
Folks,
I'm having difficulty connecting to python-forum.org and am trying to figure out where the problem lies. The website is active, so it's not a case of their server being down. And I can access it from PC's using a different ISP.
I can get it to connect if I change my routers DNS setting from 'automatically get from ISP' and manually put in a public DNS server, so I think the problem lies with the Plusnet DNS - but my techie knowledge is a bit lacking, so this may be incorrect.
Does anyone else have this problem?
python-forum.org
I cant ping it 64.157.176.245 nore can i get the webpage up and I am using opendns for dns. It resolves the ip to 64.157.176.245 so its not a dns issue.
python-forum.org
It is not responding to any requests on port 80 so it looks like the webserver it is on is having problems or the website is down.
megadyptes
python-forum.org
Weird.
I don't think it's a problem with their site as adding the following to my hosts file allows me to get to the site, so their server certainly isn't down:
64.157.176.245    www.python-forum.org
If I remove that from the hosts file then ping www.python-forum.org just reports an unknown host whereas ping 64.157.176.245 results in the usual stats. To my limited understanding of things, doesn't that mean it's failing to resove the address somewhere - so that suggest the nameservers, yes?
I could be talking rubbish, mind.
python-forum.org
Hi
I have one of PN's DNS as my prefered servers, with one of the OpenDNS servers as a fail over.
If I try to open "www.python-forum.org", after some time I get "Could not connect to remote server", where I would expect to see the default OpenDNS error page instead!
So I tried it using a web proxy and found the site opened fine.
Therefore I can only assume it is something regarding the IP range that we use being blocked by them.
Try this link using a proxy > http://anonymouse.org/cgi-bin/anon-www.cgi/http://www.python-forum.org/
*EDIT* Regarding the IP range;
I am on the 212.159.xxx.xxx range.
