problems after a machine format
i just formated my machine, put xp back on everything (drivers and the like) is installed, i have a binatone 500 adsl usb( the 2 lights one)
the problem is it connects to the internet but it doesn't do anything, its not good
Have you installed all the XP patches/fixes from windows update?
The drivers for the old Binatone 500 ADSL needs SP1 installed before it will work properly.
Have you entered your plus net user Id and password correctly?
is there a free number i can use to download sp1 then becouse im using the 0845 number atm, i'm already paying for adsl, i don't want to pay any more
Did you not recieve SP1 on CD as part of your machine?
Visit HERE. Well worth the wait for it.
i'd rather not wait that long to use my connection
The other option is to go out and buy a network card and Ethernet modem/router to replace the USB modem. Much better in the long run anyway and will work without SP1. The Ebuyer 8000 (actually an Origo ASR8000) + lan card should be no more than £40 + delivery.
Or find a mate who can download SP1 from microsoft and put it on a CD. I always download any patches and save them to my Patches CD which makes rebuilding a PC much quicker.
I save them all to another hard drive, quicker still....!
