problem with alcatel speedtouch usb modem connection -help !
Dear All,
I was a BT adsl user before I join Plusnet.
My problem is that I could not get plusnet adsl connection using the usb modem. The error occured said the remote connection was refused.
I did the normal setting ie. connecting through pppoA, using my username@plusdsl.net, set dns to 212.159.13.49 & 50, I just seems to go no where. Any advice would be very much appreciated.
Lee
