problem with activtation
I have recently has an ADSL installation cancelled due to there not being enough power going through my BT line, my question is: Is it not up to BT to fix or replace my line to enable me to recieve ADSl? and if not, why isn't it? I believe this is a requirement of the law in other countries, are we not the same in the UK?
RE: problem with activtation
According to the logs on your account the line failed due to excessive line loss. Sometimes BT may be able to improve the quality of your line if you give them a call on 151 at which point we can resubmit your order.
Regards,
Robert
| Robert Kelly........................Unmetered & ADSL solutions
| Customer Support...........................for Home & Business
| PlusNet Technologies Ltd...............http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----------
Hi, thanks for you prompt response to this, I have been in touch with BT and they put my line in for a gain increase which should now be complete, please could you resubmit my order please.
Stephen Harrison
If you have not already done so, please raise this as a contact us ticket. Our provisioning department will handle it from there.
Kind Regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| PlusNet Customer Support .......... for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
