problem when connected to plus.net
ever since ive been connected to plus.net adsl service, i cant use the audio and video portions of windows messenger
do u have any ideas why is it like this? or is it okay on your side?
thanks
RE: problem when connected to plus.net
I have Windows Mesenger on my Xp mate,
but i have never used the p2p chat or video yet.
So not sure.
maybe you need to alter the port settings.
Or could it be you're on the cheaper package that won't allow some applications?..
Ask tech support about this one mate.
good luck.
Jason
> So not sure.
> good luck.
> Jason
thanks for the reply
with regards to the package, i believe im with the "better" one coz i cna use file sharing programs and audio and video in my yahoo messenger are working, its just the windows messenger that cranks up, but if i connect using dial-up, i can use the windows messenger without changing any config, so i really think there's some ports that are blocked by plus...? im really not sure :-)
maybe i need to address plus regarding this...
