prioritise real time services
Having a few computers connected to a 1Mbs connection, is it possible to prioritise real time services such as skype calls so a download on another computer does not cause problems with the call?
u might need to mange ur network traffic.
u will require a router that will do that.
not sure if any software is avalible which lets u do it
What you need is a router which has QoS support.. there are few in the market and the most popular ones are the Draytek and Billion.
LiamM
Tell ya what I'm trying to do at the moment is configure Windows Small Business Server 2003 as it has inbuilt routing services and QoS. It's a learning curve I tell thee, but it should yield impressive results if and when I can get it to work...
