poor upload via ftp with 1mb
Traceroute Results: View Traceroute
Traceroute Time (24 Hour): 22:30 to 22:50
Traceroute Duration: 20 minutes
Traceroute Packet Size: 64 bytes
Packetloss in Traceroute?: Yes
Exchange: Luton
Problem: Other (Please explain below)
Other Problem Experienced: Slow upload on FTP. When I had 512Kb my upload was 40KB/sec consistent. Now 1Mb - best is about 29KB/sec sometimes up to 37Kb/sec.
Duration of Problem: More than 1 week
Minimum Speed Achieved On PlusNet Speedtest: 934.6 kbps
Maximum Speed Achieved On PlusNet Speedtest: 945.3 kbps
Average Speed Achieved On PlusNet Speedtest: 939.95 kbps
Account: ADSL Home (Self Install) - 1mb (50:1)
IP Block Size: Single (default)
Ticket Number: None
Additional Information: Download OK.
Upload Slow to a fast FTP Link - VIO
When I was on 512 my upload on ftp was consistently at 40KB.
Since moving over to 1mb my upload is now 25's 27's sometimes up to 37Kb/sec.
Didn't expect slower upload for more money :-(
Maybe if I downgrade it will get faster...
Regards
Les
I'm pretty sure that the max upload for 256 is about 32k, what are you using to measure your upload?
Cheers
Zen
Err, are you sure about the upload being 40KB as that is not possible on an ADSL line. Your physical upload speed is at best 256Kbs (32KBs - in practice it will be nearer 28KB-> 30KB) and is exactly the same whether your on 512K or 1Mb connection.
So what you are seeing now is correct for the upload speed you have.
I suspect what you are using the measure the upoad transfer speed is not accurate.
I upload to a client on VIO (as far as I know a fast prefessional ftp service)
Run the ADSLguide speedtest which will gve you a faily accurate idea of the max upload speed you can achieve. 37KB -> 40KB upload is not physically possible on ADSL.
should my speed not increase moving from 512 to 1mb - because it doesn't appear to be moving 100mb files any quicker - about just over an hour...
Upload is 256kb on all ADSL doesn't matter if it's 512, 1MB or 2MB, upload is still 256kb.
Cheers
Zen
Re: poor upload via ftp with 1mb
Download yes, upload no. ALL ADSL lines supplied by BT (and used by plusnet) on IPStream have an upload of 256Kbs.
sorry for my ingnorance - didn't realise the upload stayed the same...
