pings
pings
LO all ive noticed something about my gaming pings there usually about 25 to 40 on my 1mb line. But now this has gone up to about 40 to 50 which is not good and effects my gaming quite a bit. Now the thing is i dont use firewalls and i dissable antivirus (and i know tweaking wont help neither). Im connected through a draytek vigor 2600 4 port router on my single pc and it gives excellenct results with gaming pings. Im on a 50-1 contention but i dont think this could be the problem. Even when its peak time when its busy i still used to get a gaming ping of 25-40 which is great for 50-1 ratio. I just dont know what the problem is, one day i go online and pings crap and it has been now for the past 4 weeks. Also my downloads speeds are great but my gaming isnt Sad. its a mystery. Id like it if anyone would help.
pings
1. you aren't sharing your connection between 2 or more pc's and they are actively in use Online when gaming?
2. if no to 1. then you need to do a ping trace to find out why the pings have increased, could be a router/node in line to the game serve4r you use that is understrain. If its a PN router then they can do somehting about it, if not then you have to do a whois lookup to find the owner and mail them to let them know.
Try this free Utility for the ping trace if you dont have it or other utilitly already
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
pings
lo,also do you have any sypware on your machine,they can effect pings as well ad aware and or spybot search and destroy will clean your pc up.i use both as they each find stuff that the other doesnt
pings
hey adp450 yeah im usin an ADSL router with 1 computer m8.
pings
heres the results on WIN MTR
| WinMTR statistics |
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| my.router - 0 | 228 | 228 | 0 | 0 | 15 | 0 |
| lo1.plusnet.pth-ag2.plus.net - 0 | 228 | 228 | 15 | 26 | 47 | 31 |
| gi1-2.vlan3.pth-gw4.plus.net - 0 | 228 | 228 | 15 | 27 | 47 | 32 |
| gi5-0-4.pth-gw1.plus.net - 0 | 228 | 228 | 15 | 27 | 32 | 31 |
| atm0-1-0.ptb-gw1.plus.net - 0 | 228 | 228 | 31 | 35 | 297 | 31 |
| vl4.pri.ptb-gw4.plus.net - 0 | 228 | 228 | 31 | 33 | 188 | 31 |
| portal.plus.net - 0 | 227 | 227 | 31 | 32 | 47 | 31 |
|________________________________________________|______|______|______|______|______|______|
WinMTR - 0.8. Copyleft @2000-2002 Vasile Laurentiu Stanimir ( stanimir@cr.nivis.com )
pings
Have you checked your exchange HERE
pings
I ment to do the ping trace to the game server IP not the portal, as you will have different routing to the game server. Occasionally the game server I admin, I'm routed via germany to it. So that throws up odd pings with the extra hops involved but thats outwith PN's control so nothing they can do about it.
pings
philip my exchance is green can u give me a bit more help PLZ :x
pings
here are the results m8 this time ive did it to the game server
| WinMTR statistics |
| my.router - 0 | 192 | 192 | 0 | 0 | 0 | 0 |
| lo1.plusnet.pth-ag2.plus.net - 0 | 192 | 192 | 15 | 29 | 32 | 32 |
| gi1-2.vlan3.pth-gw4.plus.net - 0 | 191 | 191 | 15 | 30 | 47 | 31 |
| gi4-0-22.pth-gw2.plus.net - 0 | 191 | 191 | 15 | 30 | 32 | 31 |
| fe0-0.lonrhr1.as8838.net - 0 | 191 | 191 | 15 | 31 | 47 | 32 |
| ge0-0.lonrhr2.as8838.net - 0 | 191 | 191 | 15 | 31 | 47 | 31 |
| dedicated32.multiplay.co.uk - 1 | 191 | 190 | 15 | 31 | 47 | 31 |
pings
hello the results of win mtr are there can anyone help plz
pings
What are you expecting because the ping time averages of 30ms look fine to me.
