@ people on Inverness - Macdhui Exchange Attentuation figs
Are you noticing your router / modem reporting higher attenuation than normal the last 2-3 days? Mine is hitting 59db at times when its normally 48-51db.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Plusnet Staff
Plusnet Staff
That area wasn't affected by the Manchester fire, although some places in Scotland were. You might just find that it's the local conditions, have had a lot of rain recently?
well there staying higher than normal, even if there was bad weather which there hasn't been any in the last 5 days. But BT did work on my exchange last week and wondering if this is related.
Plusnet Staff
Plusnet Staff
It could be related, although an increase in line loss is more likely going to be something specific to your line. If it's actually causing a problem we can raise it as a fault.
I am on Inverness as well and I have noticed that I have being dropping packets recently. As well as this I am only getting about 85KB/S on a 1Meg
