password problems
password problems
Hi i bought a second hand speedtouch 576 modem router and everything is working fine only problem i have is when i try Dr speedtouch to get my line stats its says that it is password protected any ideas would be appreciated Wink
Njal
password problems
The standard username is 'Administrator' with a blank password for Speedtouch routers, some may have used Name:'admin' and PW: 'admin'.
Otherwise you could probably do a reset to factory defaults, I don't have the manual for this model, but it will be on the Speedtouch website.
http://www.speedtouchdsl.com/
Regards,
Neil
password problems
thanks but no good have tried those i have found out how to get my speed through the router but not my stats Cry
