outlook express settings
timps
have upgraded hardware from dynamode USB modem to dg834g modem / router. Any advice on e mail settings would be appreciated ...
I am unable to open outlook express Duhhhhh !
thx
timps
All the settings should be the same with the execption of the connection settings. Remove any reference of your USB modem and Outlook express will then presume you are connected permenatly which is / should be correct.
timps
Thx hadn't deleted old stuff must have been having a blonde moment
timpa
