only 80k upload speed!
rikmoncur
anyone else having slow upload speeds today?
upload speed
Upload speeds have been fine, but my download speeds over the last few days have been erratic to say the least........(high= 975, low= 551,) 1meg connection, and it's not just a peak times.
What ADSL equipment are you using?
Does it show your sync speed to the exchange? If so what is it.
The upload speed is rate adapted so will sync at whatever speed it can at the time of the last disconnection and will remain at that speed until you disconnect again.
If it is showing a low sync speed, try disconnectinmg and reconnection ADSL and see if that improves things. Do this anyway and see what happens.
rikmoncur
back to normal
I did disconnect and reboot a few times - didn't make any difference.
Did a few speed checks with adsl.org and it said 80k at max - just at the time when I had to upload a lot of stuff this afternoon.... frustrating!
This evening, it's back to normal again.
I use a USRobotics external modem and it's been quietly doing its job since August 2002.
