ok whats best settings u all got and dl speeds.
as subject says
what settings u got on yuer modem and what kind of speeds u getting.
RE: ok whats best settings u all got and dl speeds.
> as subject says
mtu 1458 - rwin 14180.
I get 58.9 down and 30.4 up. (measured from ADSLGuide speed tester.
Fastest I ever got from plusnets bigbrother was 749.30Kbps (93.66KB/sec) not bad froma 512 line.
R
> > as subject says
> R
How do you change the settings. I am using the Dynamode A360 USB adsl modem?Huh
ADSLguide speed test says..
Downstream 466kbps (58.3KB/sec)
Upstream 247kbps (30.9KB/sec)
Not bad considering I've not changed any of the settings from default !
If you need to change your settings, this link contains some useful information, including tips on using DrTCP...
http://www.the-scream.co.uk/html/resources/adsltips_old.html
Mike.
