nuffin is downloading at all ,please help
hi all for about a month ago now, nuffin is download on my pc,
i have tryed using kazza but nuffin downloads at all
i try to use bit torrent and nuffin downloads at all
and same as my dc ++ i connect and then try to connnect to a hub and it just says no connect or timed out
what u think could be doing this as was working before and i have not changed no settings of what i know of
does anyone have an ideas
thank your
scott
LiamM
What Plusnet product are you connected to?
ADSL Home Surf perchance?
urm yeha i tihnk it is i have had it liek 2 years now urm it is 512k i think it is home surf how i foudn out?
and have they changed something then?
yep it is home surf
LiamM
This is why. Home Surf always has been an account designed to block P2P usage (things like Kazaa, Torrent Downloading etc...).
Recently, Plusnet have introduced some new kit which is more clever at detecting P2P activity. You have been lucky that it worked before.... but now, unfortunately, there is nothing you can do about it.
To solve this problem, you should consider upgrading to Broadband Premier (£21.99 - Upto 2Mb). All traffic is allowed and no shaping applies. It's free to upgrade.
