no ping
no ping
nobody can ping my new officeconnect 612! is it a configuration problem or else?
What do I have to do?
Thank you!
chino
RE: no ping
It's most likely a firewall, if i turn my off i can ping but if it's on i cannot...
cUnDaLl
1.7 GHz AMD XP, 768MB DDR PC2100 Crucial, 120 GB HD IBM Deskstar
Why do we do it because we can...... Smiley
RE: no ping
It's when a remote computer tries to ping me! it doen't work! The router doesn't respond ! I was thinking of port forwarding but the ping is an ICMP command who doen't have TCP or UDP layer so no port!
Thank you
RE: no ping
I think what the reply (replyee?) meant was that when he turns his firewall off he can ping his router from an external PC Smiley
You router sound like it is configured to drop the packets and I wouldn't worry about it if everything else works. Unless of course you need to ping it for some reason...
Ed.
