networking fand sharing family PC's
Have hit a problem when trying to network 3 PC's; essentially to try to share our ADSL connection;
The modem is the standard USB, Binatone ADSL500 unit. If I enable the integrated Realtek RTL 8139/810x family fast etherenet NIC in the pc, ( a shuttle SK43g,) the USB modem stops working. the only cure is to then disable the NIC , reboot the PC and reinstall the USB modem. There is obviouly a conflict between devices here, has anyone any idea of the preoces required to enable them both to run happily together?
I have an idea it involves setting Ip and mAc addresses tothe NIC that do not conflict with the USB modem, but am not sure where to begin.
reply to gps@smout.co.uk
It would save you a lot trouble and make life so much easier if you were to bin the USB modem and get yourself a router.
They make sharing the ADSL and networking that much eisier, and you don't have to have the main PC on all the time.
You can pick up a 4 port router now for as little as £40 see http://www.scan.co.uk
runhare
Cool
yes i'm coming to that conclusion!
It's doable for 2 PCs but not for 3. You really do need a router.
A good cheap model for about £30 is the ORIGO ASR8400 available from www.ebuyer.com. For more expensive models the Netgear DG834 will do the job for about £70.
If you want to go the wireless route then the Netgear DG834G or Linksys WAG54G is recommended, both around £100 + cost of WiFi cards for the remote PC(s).
runhare
thanks for al your advice; we already have some kind of router with 4 network ports and a WAN port plus a serial connection. CAn anyone recommend an ethernet broadband modem , shoudl there be such a device?
Graham Smout
Yes, the only one I know of is the D-Link DSL300T but it's more expensive than many all in one ADSL modem/routers at around £50. If you are prepared to pay £50 for that, I suggest you just buy the Origi ASR8400 as it will be much simpler to setup and get working than 2 devices as you would have with the DSL300T + your router.
zpeterk
I can recommend a 300T and there are down to £37 now
