netgear 834g and linksys usb adapter
Hi I have a netgear 834G modem router wireless accesspoint combo thingy and have a machine with a linksys wusb11 usb wireless adapter. the prob with this combo is that the connect on the machine with the linksys keeps dropping randomly. Any ideas what the matter may be? I have a centrino laptop which connects to the 834g without any probs.
How far apart are the two devices and though how many walls is the signal going though?
Is the linksys wusb11 usb , of the same network type as the netgear, i.e 802b etc. (I'm using 802b as an example)
Aaron
Hi there is one floor between the two - preety much directlu up. I believe that the network types are the same. How can I tell? Thanks.
