need to know which ports to open
i have dowloaded and subscribed to limewire music site and apparently need to open a port on my router please can someone tell me what i need to use as its driving me crazy......... thanks
Alecto
According to this, (which I found by using Google) the default port is 6346, but you are recommended to change it, as default ports are never a good idea. Change it using the advanced features to something in the 40,000s.
If you visit http://www.portforward.com/default.htm
This will tell you the ports and how to set them up on your router
