need help
need help
I signed in for ADSL Home Self install on 5/8/02. My line was activated on 3/9/02 and I received Starter pack on 11/9/02. However, I have not been able to connect to broadband.
Sync is established but I cannot connect to broadband.
The error code is that my username/password is invalid; however, Customer Support told me there was noting wrong with my username/password.
I really disappointed with PlusNet's services.
I used BT broadband before changing to PlusNet.
I would be grateful if anyone can give me some suggestion for connecting to broadband.
Thank you very much.
RE: need help
And they never sloved it for you? WTF..
make sure its username@plus.net, also the username you use to sign into the portal should be your user/pass. i think im not staff..
They never helped you get online? i dont understand that....
RE: need help
Please accept our apologies for not helping you more with your connection problems, however as you know we have already raised the fault to BT for investigation.
I have performed some maintenance on your account and I would ask that you re-test your username and password.
Please use the @plus.net realm as I have checked and this is the realm that your ADSL was provisioned for.
Kind Regards,
Russell.
| Russell Till.......................Unmetered & ADSL solutions
| Technical Support .......................for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ---- My Referrals - It pays to recommend PlusNet ----
