need help on tweaking mtu/rwin and modulation settings
hi lads/ladies etc Cheesy
umm basically i need some help on tweaking/changing my mtu/rwin settings, please note that i am a gamer so my settings need to help me get the most out of my online gaming :~D
so please could you recommend me: mtu,rwin and modulation settings to help me get the most out of my gaming, i own dynamode conexant accessrunner (using .50 drivers ShockedD) and yes i knw that its not a very good modem but it came with the package Wink
extra note* ive tried 1478,1430,1458 - using rwin from dslreports.com/tweaks - maybe you add your own personal rwins Shocked)
thx for help
hang on m8 1478 etc is MTU settings
yes i knw those are the mtu settings Wink but i am asking which mtu settings/ rwin settings/ modulation settings i should use, relating that to online gaming - so i'd have the internet optimized for use with online gaming < hopefully i made it abit clearer :roll:
There is little point asking others, as what works for them, may not work for you.
Your best bet is to experiment.
I sugest visiting THIS page, where you can find some good information on the sort of settings to use.
vic_newey
thanks for that link acarr, been using 1478 but set to 1430 & 13900 & getting speeds 475 - 8 ( usually 470), browsing faster now , less page errors
