nag screen
nag screen
How can I stop the screen asking me do I know or want to, connect to a secure site? I have every time I click the bloody mouse it seems and it's driving me potty!!!
Geoff 22 :twisted:
nag screen
Use autologin
Problem solved.
nag screen
Delete the 's' from 'https' in the url in the address bar.
nag screen.
yes that does it, Thanx
Smiley
nag screen
This is caused by the fact that you have visited a secure part of the portal e.g. My Account.
unfortunately this security "Sticks" with you after you leave and brings up trhe annoying prompt.
Just go straight into the forums from the home page and you will not get it.
As mentioned above you can also edit out the "s" from the http in the address bar and that will clear it.
kissack
nag screen
cheers! This has been bugging me of late to.
nag screen
Phew, glad I wasn't the only one. All is well now thanks to you eggspurts!
Geoff Tongue
