my broadband is slower than dial up
hi all my speed seems ok but when i conect but all of my web pages are loading slower than dialup
athlon xp (512 ddr) 80gig hard drive windows xp iam sure it is not plus .net could internet ex have anything to do with a very slow computer
thanks
Delves
RE: my broadband is slower than dial up
You must have read my mind. I'm fed up know, Almost same spec system as you and my web pages are taking so long its unusable. I've contacted +net, sent tracert results etc and all the times seem ok but my page load times are taking as long as it takes to drink two cup's of tea.
Help anyone, I'm using IE6 SP 1.
Delves
By the way I must say this forum flies in, no slow down with this site. Whats going on.....
fonejacker
What results do you guys get from the speed tester in the "My Connection" area of the portal?
Regards,
Ian Wild
PlusNet Customer Support
Delves
> Regards,
> Ian Wild
With the old test meter as follows
PlusNET Technologies Bandwidth Meter
Your current bandwidth reading is:
37.00kbps
which means you can download at 4.63 KB/sec. from our servers.
37 kbps YOU
53.3 kbps 56k Dial Up
64 kbps ISDN 1 Channel
128 kbps ISDN Dual Channel
500 kbps ADSL 500
1000 kbps ADSL 1000
2000 kbps ADSL 2000
Retest Close
With the new file download meter as follows
PlusNet Bandwidth Meter
455.20kbps
Which means you can download at 56.9 KB/sec. from our servers.
455.2 kbps YOU
500 kbps ADSL 500
1000 kbps ADSL 1000
2000 kbps ADSL 2000
Retest Close
I don't understand it, all I know is my web pages take forever to load.
Im also suffering slowdown although it isnt much, a drop of about 80kbps, i normally get around 460kbps, but i did notice it i must be sensitive or something Smiley
Here are my readouts, useing +Nets own speed test to its servers and also adslguides speed test giveing the slightly larger picture to the UK end of the internet.
+Net Bandwidth Meter
383.20kbps
Which means you can download at 47.9 KB/sec. from our servers.
Adslguide
Downstream
373 Kbps (46.6 KB/sec)
402 Kbps (inc. overheads)
Upstream
240 Kbps (30.0 KB/sec)
259 Kbps (inc. overheads)
The downstream throughputs are very similar with the
web only slightly slower than my feed to +Net which seems to me that somewhere between me and +Net servers is the bottleneck point in the link if the adslguide test is to be believed.
My network settings have been tweaked under Win2k and Linux for MTU=1458.
Hope info helps
Ali
I did a test on mine and it says
484.90kbps
Which means you can download at 60.61 KB/sec. from our servers.
> > Regards,
> > Ian Wild
> 37.00kbps
> 37 kbps YOU
> 500 kbps ADSL 500
> 1000 kbps ADSL 1000
> 2000 kbps ADSL 2000
> Retest Close
> 455.20kbps
> 455.2 kbps YOU
> 500 kbps ADSL 500
> 1000 kbps ADSL 1000
> 2000 kbps ADSL 2000
> Retest Close
