my adsl modem
my adsl modem
i was on the phone for 1hour try to get throught to techical support i got throught then i was cut off,
i got number 4511233
could you tell me if i got aadsl line because i can not use`s it my modem is us robotics plus could send me the setting for itso i can use it as i am thinking about cancel my payment for may 3 2002 as i pay april months and i can`t use it .
1 REPLY
RE: my adsl modem
The settings are as follows.
Username: <your username>@plus.net
Enter your password as usual
Below are a number of additional settings which you may be required to enter as part of your ADSL set-up process. You may not be required to manually enter all of the details listed, particularly with many USB modems. Due to the 'plug-and- play' design of these modems, these settings may be automatically detected.
Data circuit information
VPI (Virtual Path Identifier) - 0
VCI (Virtual Channel Identifier) - 38
Data Link Encapsulation: PPPoA
PPP properties: VC Multiplexed
Kind Regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| Technical Support ................. for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
