my adsl max connection stuck at 130.00kbps
The above title says it all really. This has been scince friday . My modem is syncing at 6meg but my speed is only 130kbps max.
Done the broadband fault checker no problems there.
19-03-2007 00:25:21 129.2
19-03-2007 00:24:49 129.1
19-03-2007 00:24:20 127.2
18-03-2007 16:55:15 132.3
18-03-2007 16:54:45 126.4
18-03-2007 11:13:14 129
18-03-2007 11:12:17 129.4
14-03-2007 21:36:34 594.6
14-03-2007 21:35:55 464.6
14-03-2007 21:34:17 495.6
24-02-2007 18:49:27 4883.9
and some more info from the bt speed test
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 135 kbps
DSL connection rate: 448 kbps(UP-STREAM) 6304 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 84 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
and my profile from Plusnet says
Your current broadband speed is 500 Kbps
Any help please
Thanks Coley
Fixes: 8
You may be synced at 6304 now, but sometime in the last three days or so you have synced at around 135. You need to track down what caused that low sync.
If you remain synced at your current speed it will rise again automatically in around 3 days.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Spot on there Elvin yes on saturday I moved my computer downstairs and it did sync for som unkown reason at that speed. However this only happened once for a short while I rebooted and it synced at 6meg and surfing and download speeds were good.
So what happens now how do I get it back to normal
Thanks for quick reply
Best regards Coley
Leave it for 3-5 days. If you remain synced at that speed it should all return to normal.
Not a lot PN can do, this is down to the way BT run MaxDSL at the exchange.
Plusnet Staff
Plusnet Staff
Fixes: 159
As long as the router doesn't sync low again in the next 3 days the IP profile should be lifted again. If there is no change after 3 days then let us know so we can have a look.
 Chris Parr
 Plusnet Staff
