my ADSL line was activated 5 days ago, but i can't connect b
I have called the helpline many times, but no one can give me a definite answer of my problem. Can anyone help me about it? Thank you.
1 REPLY
RE: my ADSL line was activated 5 days ago, but i can't conne
If you have a look at contact us. You will see that after your call to support, a fault has been raised to BT.
We now await BT to check the work they did. As it is liukely that they did not configure your line correctly.
Kind regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| PlusNet Customer Support .......... for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
