mtu
mtu
sorry im quite new to this so what is this mtu people are going on about.cheers for any help
dale
RE: mtu
Maxium Transmitable Unit is the size of the packet you send and recieve if its wrong it get fragmented and has to be rebuilt which causes loss or slow speed. For dial up its normaly set low but for lans and adsl its around 1500.
The problem is people are reseting theirs at a guess and its diffrent for each set of equipment. You need to test your own to get the best. go to
http://www.dslreports.com/tweaks
to test yours
Bt do a MTU set prog here
http://speedtest.btopenworld.com/mtu/
lots of info here
http://www.adslguide.org.uk/
Hope that helps
> dale
RE: mtu
> dale
I found setting my MTU to 1458 made a big difference. I used DRTCP to change the settings, can't remember the address but DRTCP typed into Google will find it.
RE: mtu
thanks for the info will check it out.dale> Maxium Transmitable Unit is the size of the packet you send and recieve if its wrong it get fragmented and has to be rebuilt which causes loss or slow speed. For dial up its normaly set low but for lans and adsl its around 1500.
> to test yours
> lots of info here
> Hope that helps
> > dale
RE: mtu
>cheers for the info ill check it out.
dale
> to test yours
> lots of info here
> Hope that helps
> > dale
