msn messenger connection dropping
I have noticed that msn cannot hold a connection. I am behind a router and it happens on both of my pc's. They cant seem to hold an msn connection, but can usually reconnect straight away.
Now im wondering if this is something to do with my router, or other ppl having the same problem.
1 REPLY
See http://messenger.msn.co.uk/Status.aspx
They are having login problems.
