modem recommendations?
nogginthenog
will be able to get broadband come september hurray! thinkig of buying my own ethernet modem just one pc running xp is theb D-Link DSL-300T ADSL Ethernet Modem a good choice any recommendations appreciated
If you intend to add additional PCs in the future no.
For the same price (and even cheaper) you can get a fully functional 4 port ADSL Modem/router that will be much better. It's the ORIGO ASR8400, available from ebuyer for about £30. For a bit more you can get a better product like the Netgear DG834.
You will be better off in the long run to get a ADSL modem/router rather than just an Ethernet modem in my opinion.
Having a DSL-300T myself I'll 2nd what Peter said.
Although easy enough to setup, it refuses to work on Xbox live or with my Linksys router.
I have just sold it & am likely getting something like the one Peter mentioned.
