maxdsl only giving 29% of line speed **now 62%!**
I just completed a speed check using the speed checker at dslzone after running the test it tells me that my download speed is ony 29% efficient.
Tester: http://www.dslzoneuk.net/speedtest.php
Results
http://www.dslzoneuk.net/speedtest/testresult.php?result=2283.4&test=7776&date=1148743183
it also shows that some maxdsl customers are getting higher speeds so I guess not all hope is lost.
A
I find that speedtest good but it is used a lot so try others, for example
http://www.speedtest.bbmax.co.uk/
The results from both are similar. I use a number of tests. This one just highlights the poor speed by way of percentage.
Cheer
A
I can't get decent results using that first tester! ie 23% or below 2mbps
And around 3mbps on the second tester.
However I know that I am getting around 5-6mbps on real world downloads, so who cares what a speed tester says? Smiley
seventhstar what speed are you getting on downloads?
Cheers
A
daviez
Wonderful, another web page to confirm some combination of BT and Plusnet is crippling my 7Mb ADSL connection...
http://www.dslzoneuk.net/speedtest/testresult.php?result=3782.8&test=7104&date=1148829927
vic_newey
same here in that I sync at 1888 or 1950 or 2.1 but cannot utilise the speeds because I am set at 1500, speedtester often shows 1498 or 1500 on a good day even tho it could go higher
As I connect several times a day I get a new resync each time, I am using a USB modem at the mo as my router won't sync anywhere near as good, think I will look for a new router with the Ti chipset as its supposed to be Max friendly
daviez
Much as it pains me to suggest it, I think the best kind of modem to get around the poor MaxDSL performance is an NTL one...
Cheers
A
Hi
As I said in my previous post, I get around 5-6mbps on realworld downloads. Thats why I don't pay too much attention to speed test results.
daviez at least your getting up near the 4mb speed I to have line speed of 7mb but have not really managed to pass 3 on a rare occasion, mainly always 2.5
A
came home today to find speed has jumped up dramatically.
http://www.dslzoneuk.net/speedtest/testresult.php?result=4836.5&test=7744&date=1149008871
The only thing I have done differently is leave the modem off from 7:45 ish this morning until I came home about 6pm.
Think I'll leave it off tomorrow too.
I have turned it off in the past as advised but only for a hour or so seams that leaving it off longer may yield better results.
off to see how quick I max my downloads before my new monthly total starts on Saturday. :lol:
A
