mac code
mac code
i asked in a ticket for my mac code on sunday at 3.30 pm it said tickets were being cleared in approx 10 hours now over 36 hours later not a tinkle..is this usual for ppl who are leaving...(16327450)
LiamM
mac code
The average figure given is currently incorrect as there is currently a bug with the counter.
However, rest assured your MAC key should be dealt with soon. The department authorised to generate MAC keys only work Monday - Friday 9-5 (the times that BT work) and are therefore generally quite busy.
Given that there is a 30 day notice period, and this is taken from the day you request the MAC, not the day you get it, it wont make any difference to you.
mac code
so does that mean i have to wait 30 days to get code..sorry if im being dumb here,cheers for reply...
mac code
It can take up to a week for Plusnet to issue a MAC code but usually it's 2 or 3 days.
mac code
ok thanks
LiamM
mac code
Nope, the code will be generated once your ticket has been picked up, in the next couple of days.
