lost my cable for a USB Binatone 500
help! lost my modem to phone line cable for my binatone adsl 500, can i get another one off you guys or can u at least tell me wot its called so i can buy a new one?
Man, moving house sucks, losing cables, 65 quid fees to move my adsl, bah.
Do you have an old 56K modem? If so, use the phone cable it comes with. Even the cable that comes with a normal phone may work if it has the American style RJ-11 connector.
Failing that you need a RJ11 plug -> BT phone plug cable which you may find in a hardware / electronics shop.
fantastic thanks. yeah i got loadsa old 56k cables, i didnt think they would work tho. cheers.
Some will, some won't, It depends on the modem manufacturer. But try several if the first does not work.
coo' the wonders of modern technology, eh?
Btw, i have just got a pc with an intergrated LAN card (nforce2) and I have an ethernet cable so what do I need to run my adsl through that? do i need to upgrade/change my account or do i just need some hardware? will it improve my connecton if i run it like that instead of thru the binatone?
cheers!
you would need to get a router to use the on board lan card, so doing away with your usb modem.
Using one won't speed up your connection but it will help remove a strain that the usb modem puts on your pc, so for games online you might see a difference if the games play smoother.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
thats wot i like to hear, anything that boosts my gaming performance is always worth a shot, cheers!
