lost connections/not a bt fault
pc keeps dropping the line-can anyone help?
m/board abit kt7-raid with updated via 4-1 drivers made no difference
athlon 850 cpu
voodoo 3000 tv out
vibra 16 s/card
320 mb sdram
ext dynamode usb modem-think it may be a usb problem
modems ok using a freinds pc at the mo connected now for 24 hrs no probs.
please help-on going now four 5 weeks ahhhhhhhhhhh!!
kiasu
RE: lost connections/not a bt fault
> athlon 850 cpu
> voodoo 3000 tv out
> vibra 16 s/card
> 320 mb sdram
Steve,
I have had the very same problem the last few days. Prior to this I have had many moths service with Plusnet without this problem..
Don't know why it does it.
Mark
I kept loosing connection all the time for nearly two weeks.
I found out if you have a VIA chipset on your motherboard this can cause a power managemnt problem as USB Modems take a lot of power.
I had to install a PCI USB Card, since then ive had no disconnection problems!
Hope this helps
Try unplugging any other USB devices you have and see if it fixes it.
Or try using a powered USB hub.
Chris
> Hope this helps
thanx amanda can you recomend a specific card?
ie make model-usb1 or 2
many thanx
you should be OK buying any moderate USB 1 or 2 card. Take a trip to PC world - they are all usually OK.
Hope this sorts your problem.
Chris
(I always feel you are better paying a couple of quid extra over the cheap & nasty stuff whatever you are buying!)
Chris
Anycard will do Steven, I got a cheap one £17.99
Did the trick thank goodeness, stopped disconnecting altogether.
Hope this helps.
> Hope this helps.
went and purchased a usb card-running now for 18 hrs
no problems
many thanx to you all
steve
