line upgraded?
dragona
line upgraded?
hey, woke up this morning and found that my router was saying i had
288 Kbps Upstream,
2272 Kbps Downstream
i was on a 1 meg premier account ...
now ive tried a download and only appear to be getting about 120 - 130 K just wanted to know do we have to wait for plusnet to do something before we can download at max speed? because i was able to download at the same speed before. :\ i tried rebooting my router and nothing changed.
Thanks -Dragona
Alecto
line upgraded?
see this post:
http://portal.plus.net/central/forums/viewtopic.php?t=26923
looks like the same problem.
dragona
line upgraded?
thought it might be something like this wasnt sure ^.^ maybe they should put a sticky topic about speed upgrades ^.^ guess i'll just wait it out
Edit: And thanks for the quick reply ^.^
line upgraded?
Some times i used 2 get incorrect speeds showing. Once it said connected at 8mb then 2mb. Its just mental
dragona
line upgraded?
heh, this is constnt and after 2 or 3 reconnects its till saying the same figure Shocked just waiting for plusnet to change my speed now Shocked
line upgraded?
happened to me this morning, called up pn on the phone and it took 30 secs for them to sort out their end. Couldnt wait for a ticket etc.
line upgraded?
All it takes is a refresh of your connection at both the Plusnet end and your end. They can do it if you call them but I see they are getting many requests for this now.
Regards.
dragona
line upgraded?
well if you have the free upgrade ... dont you have to wait your turn?
line upgraded?
Well, yes and no.
The upgrade has occured.
Plusnet just don't know it has.
