line noise
tonka
line noise
hi i dont know if you can help me i have terrible line noise when i pick the phone up and i am on line ,all the filters are in the right place and i havnt had any problems with the internet just a couple of line drops,the noise only lasts for about twenty seconds but it dont half hurt your ears.
line noise
Do you still get the noise when the ADSL modem / router is not connected?
Have you tried a different filter on the modem and you phone?
tonka
line noise
not tried a different filter ,where would i get one and which type would i need many thanks.
line noise
line noise
Try the a new filter as suggested, but if that doesn't work then you may have a fault on your line.
Aaron
tonka
line noise
many thanks guys i will give it a bash if all else fails it will keep the misses of the phone.
line noise
tonka told you before its that nasty extension you have the computer on
