line drops
line drops
is there any way my line keeps dropping because the exchange and/or plusnet is too busy - seems to happen at peak times eg NOW
RE: line drops
hey i just got ADSL today and it also keeps dropping the line
the other thing is it takes ages to connect. and every so oftan the conection fails.
phil
RE: line drops
Whatever the reason for your line drops I can assure you it will not be plusnets fault (it never is), if you don't believe me just ask them.
Reset
Brickinit
RE: line drops
i think the most likley cause will be your splitter/filters, were they supplied by plus net? i had the same problem when i first connected,looked on the forums saw that there had been a problem with a batch of filters,bought 2 more filters locally ( maplins £23 )no probs. since
malc :rollsmile:
RE: line drops
> malc :rollsmile:
i have replaced my filters and an still having problems the line is connected but i can not recive data?
RE: line drops
> Nope not the filters does it to me without the filters something about the modem going out of sync they said at plusnet. Raised a ticket never got an answer just learning to live with it but it is dam anyonning.
Regards Coley
RE: line drops
If you have an AMD with a AMD 756 PCI to USB open host controller, you will need a usb add on card from the likes of BELKIN these cost about £25 from PCWorld but they do the trick.
RE: line drops
This line dropping is a pain in der bum..
Having just recently joined plus.net and choosing the PCI / ADSL option we are constantly plagued with the line dropping off.
Does anyone have the same problem useing USB / ADSL
or does the problem just revolve around the PCI option..
Does it happen during peak periods..ie..Evenings and weekends or is it random..
Does the splitters ( new issue ) cure the problem.
What chipset is on your PCI cards..Texas Instruments..?
Does the different chipset..Alcatel Network Systems Inc. give more stability.
Any feedback appreciated.It may help me to decide whether or not I need to rewire my telephone system.
Regards
Les
