latest on mtu :¬s
latest on mtu :¬s
hey umm hope u tweakers out there can help me out on this one..err last i checked 1478 was the max we cud get the mtu up to..wuts the lastest on that..settings wise that is..mtu + rwin
thx for ya help Smiley
latest on mtu :¬s
It's not the max that is important, it's the combination of MTU & RWIN that will determin your fastest transfer speed. Having a high MTU but wrong rwin can cause a slowdown.
Read the MTU Tweak thread and use the suggested software to check various MTU/RWIN settings and see which one gives you the best transfer speed. If you have a router, also check what MTUI setting it has because using a higher setting on your PC than your router will not make any difference.
mitchell20
latest on mtu :¬s
On the suject of MTU's. As someone yet to start using ADSL I have signed up for plus.net 1MB home service (hopefully) once my exchanges becomes RFS (Feb 11th)
I unterstand that I need my MTU set at 1478 on both my PC and on my DG834G router which I have changed already. I did't really understand the rest of the post or catch what RWIN (TCP receive) setting I need for 1Mb ADSL?
I have downloaded Dr TCP and just wondered what the other settings need to be set to please?
latest on mtu :¬s
MTU is the same regardless of DSL speed, so is 1478.
RWIN depends on where you want to tweak for, mainly UK surfing ro US sites. RWIN is a multiple of MTU so 31038 to 36950 are possible values for 1Mb connection
painswck
latest on mtu :¬s
Some people, myself included, are still finding that an MTU of 1430 gives the best results. It is a question of trying and using those that are best for you.
Roland
